woolie said:I was wondering if you have any guidance for building your little test rig with the JLM Powerstation? Seems very prudent/handy to have a rig to test devices.
Potato Cakes said:Does it still do it when unsoldered from the CB board (JP3-1)?
Potato Cakes said:woolie said:I was wondering if you have any guidance for building your little test rig with the JLM Powerstation? Seems very prudent/handy to have a rig to test devices.
Did you see the previous post with the edge connector pinout? Just connect the proper voltages to the correct pin then wire in a male and female XLR (in/out) also to the correct pins and then you should be great. Make sure you adjust your Powerstation to the correct voltages beforehand.
Paul
Peter, the following points are involved for the 1.5k freq. All are on the LC-EP PCB.choolder said:I just build 2 LC53a's. One works perfect, the other has a problem with 1 frequency: 1,5k. If a boost/cut at that frequency nothing happens. Any starting points were to start looking?
I am out of the metalwork and have not reordered. Not sure I will since the release of the BT50. They overlap as far as responsibilities and I think the BT50 is an better overall designed module, cleaner/easier build and sonically a tad more aggressive than the LC53A.Blackdawg said:Is this Kit gone? Not on the site anymore :'(
jsteiger said:I am out of the metalwork and have not reordered. Not sure I will since the release of the BT50. They overlap as far as responsibilities and I think the BT50 is an better overall designed module, cleaner/easier build and sonically a tad more aggressive than the LC53A.
choolder said:Hi guys,
Peter
C12 had indeed exploded and that was all the fuzzy stuff around. The part that was put in its place was a MUCH larger axial cap. I replaced it with an appropriate radial. The purpose of C12 and C13 is decoupling the power supply so the neg. lead of C12 goes to the -16, the positive lead goes to ground and Ive worked a very short re-route for the busted pad.There was this yellow fuzz looking stuff all around C14 and C12 was using a part that didnt look anything like C13. Further more. The pads on C12 are pretty shot. I'm guessing C12 exploded at some point. I can tell where the neg. pad went but I cant find the trace on the positive side pad. Does this pad indeed go to ground?
The 7.0H inductor is loose in the little plastic holder. None of the others seem loose. Should this be glued into its little holder with something like super glue? Is there a check I can do to make sure none of the leads between the inductor core and the pin got severed?
