It is most likely a bad solder joint on the toggle or on the HPF PCB. Also reflow the solder on the 5-pin 90 degree header. The audio enters and leaves the HPF PCB twice. Once for -6 and again for the -12 position.
+1, exactly what I was about to say!Potato Cakes said:Did you build the DOAs or buy them pre built? If you built the DOAs, do you have any know working ones to do some testing? Also, double check all of your solder joints, even if you are experienced at soldering......
