Thanks! Reflowing the switch makes sense because, I do remember it working when I first built it.
jsteiger said:
Well, with phantom engaged, there will always be a pop when engaging the Pad switch. Since there is DC present on the contacts, it will happen. If this happens when phantom is off, I would check for DC at the input pins of the card, gold finger #8 and #10. A loud pop when switching most usually means there is DC on the audio switch. There shouldn't be any there with phantom off. Maybe its from an outside source? Whatever is plugged into the pre's input?
Yes, it pops no matter what the source is... although I haven't checked it with a line in, but with, for instance, a plain old 57 and the phantom OFF, it pops. Did you hear the noise also? That noise is there even with the volume all the way down.
And I beg for your patience again as I ask exactly how to check for DC at gold fingers 8 and 10. Do I do this with the unit powered up and in the jig? Seems difficult as the pins are in the jig. Obviously there is basic understanding that I don't have. What setting do I use for my DMM, and exactly where does each probe go and under what conditions (powered on, off, etc.)?
And then if there IS DC there, what does that tell me? Or shall I just cross that bridge when I get to it?
As always, thank you, thank you, thank you.
