Seditionary
"When trouble shooting like this, the module needs to be flat on a bench or table, laying flat in front of you. It cannot safely, effectively or scientifically be carried out while installed in a rack."
>> how do i get power to the module if it isn't in the rack? you said it needs to be under power? could i find some other type of power generator?
Not sure what "cap" you are referring to.
>> oops, i meant resistors.
An audio mic level signal needs to be applied to the typical input for the module. This needs to be something like a 1k sine wave from a signal generator of some sort.
>> that old EL instruments circuit design system / signal generator i got doesn't power on... after i learn how to fix the preamp, i'll try to fix the instrument that could have been useful in helping to fix the preamp (or itself). i guess i need to buy some kind of signal generator in the meantime then, yeah? would you recommend buying a scope? would it make sense to invest in these things if i plan to continue building equipment from these pages? Also, is a signal listening probe something you could build or is it something you'd have to pick up?
in this description (which sounds safer to me, to have the unit not powered) --
1) a signal source (signal generator, ipod etc) with a cable that ends in alligator clips or some other type of clips
2) a signal probe to listen to the signal source
with the opamp removed and the preamp NOT powered, sitting on your bench, check the input up to the opamp non-inverting input:
A) connect signal source, to "In Hi" & "In Lo" (pin 10 & 8 on the edge connector, or the side of the 750R resistors that doesn't connect to the 160R resistor)
B) connect the 0v/ground of the probe to a 0v point on the preamp.
C) probe the non-inverting input pin on the opamp - you should hear the signal source.
D) if you don't trace the signal from the input, following the schematic - see where it stops.
my questions on this -- is HI the 6th gold finger down from the top of the unit? what point is a 0v point on the preamp? also, which is the non-inverting input pin?
sorry for the young questions. thank you to the electronic gurus (especially jeff) -- thanks for teaching.
