I was thinking of posting this in the Lab, yet this forum page appears to be the larger for the VP2x series stuff. Over a year ago I purchased a pair of used prebuilt VP2X with the VP26 RevA.2 board. Tested them, and did notice a slight difference in audio figured this was do to the different opamp in the unit. Unit A has a 2521 opamp. Unit B doesn't have a specific model marking on the board.
Over the next few months I mainly used Unit B for snare drum and a few occasional other sessions, yet hardly used the other unit. Well today I was going through my outboard gear just making sure everything is still up to par. Unit A had a major issue, a very low output and was extremely distorted. I decided to check the opamp and swapped them. Unit A then fired right up. Great, I figured it would be an easy fix and I'd had to only replace the opamp. Just to be certain I tested to "faulty" opamp (2521)from Unit A in to Unit B, and it worked just fine. I decided to compare to 2 units, and Unit A was still thinner and more aggressive sounding than Unit B. Proceeded to swap the opamp back into their original units and the issue was still the same. Unit A sounding thinner and more aggressive. I left my 500 chassis powered on for an hour, went back to test them again and the output of Unit A had dropped significantly.
Is this an issue with the output transformer or do I have a larger issue at hand?
