No problem. It's just beyond your DMM. Sounds like you are OK.
Nice!Curran said:yeah I dropped in the one of the four gar2550's and it fired right up and sounds awesome. I got three built and all the gar2550 kits done in about 8 hours. right now they are all waiting to get used on the next session!!!! the layout PDF is awesome and the build is super easy!!!
Yes, they are tiny... and a bitch is a good description too. Very rewarding though indeed.the opamps are tiny and a bitch...
letterbeacon said:I'm thinking about putting two AP26 pre amps horizontal in a 1U rack. What do I need to supply the modules with power wise? Is it +/-15v and +48v for the phantom power?
babyhead said:The problem is that my 500 rack puts out +/- 18.
babyhead said:letterbeacon said:I'm thinking about putting two AP26 pre amps horizontal in a 1U rack. What do I need to supply the modules with power wise? Is it +/-15v and +48v for the phantom power?
It depends on your opamps, but otherwise, yes.
letterbeacon said:Has anyone else put these pre amps in a 1U rack before?
haima said:jeff also makes the VP312 boards that can be trimmed to squeeze 4 channels in a 1RU box.
No, no, no...the help is appreciated indeed!haima said:oops- i should have shut my mouth - the real info, straight from the horses mouth! thanks jeff ;D
