Hey surfkat,
Can you post a pic of the top and bottom of your board?
Cheers, Jeff
Cheers, Jeff
Yes, this is true. Actually my friend Hairball Mike has a solution for this that I will probably offer too. Still, flying leads shouldn't be too much of an issue for a DIY'er! ;D3nity said:i wonder if soldering the t-pad directly to pcb will help to avoid mistakes...
I'm sure it can be done on a dual layer pcb..
don't make it too easy ;D ;D ;Djsteiger said:Yes, this is true. Actually my friend Hairball Mike has a solution for this that I will probably offer too. Still, flying leads shouldn't be too much of an issue for a DIY'er! ;D3nity said:i wonder if soldering the t-pad directly to pcb will help to avoid mistakes...
those people will learn and grow with it3nity said:I dont mind but but some people cant even solder caps in its right place...
What? 3nity, the Poor Man 660 is a legendary DIY tube comp build. Where have you been my friend?3nity said:...Whats the poorman anyways?
for sure, sorry for my comments about it.3nity said:well its a sugestion...and its up to the deisgner to take considerations...
[silent:arts] said:those people will learn and grow with it3nity said:I dont mind but but some people cant even solder caps in its right place...![]()
