Yes, correct Bruce.bruce0 said:...I presume from your description that the relay card behind the 1/4" socket is the one that is activated by the Post 2622 switch, and the one in the center of the board is activated by insertion of the 1/4 Jack. Is that correct? So the one that goes to Bo Mode, is the one near the jack?
Yes I would agree. With a 1/4" jack inserted, you should hear that relay clicking/activating when you flip the "Post 2622" switch back and forth. Without a 1/4" jack inserted, the "Post 2622" switch does nothing since it needs the ring-sleeve-ground connection made by the jack body itself.I will make the tests, but based upon the fact that the Passive didn't work either, it sounds like it is the relay card near the Jack. Is that consistent?
;D ;D 8) 8)(Luckily... and thanks to your suggestion, I have a Hakko 808... And as you said, it does just want to make me de-solder something... it works so well (I have been harvesting old mic-pre transformers)).
rob61 said:I'm interested in adding a pair of these to my new 51X rack.
1. What difference in sound is there between the FET and the IC version of the active DI circuits?
2. Has anyone tried the new 24V APP2050E DOA? I've been using the gar2520 and Red Dots in my other +16 CAPI pres. How would this compare in sound?
