Hey guys,
I’m building this mic pre, and I’ve ran into a problem, and there doesn’t seem to be a resolution through out the thread. Upon placing the sub DI 1 and placing it as described in the thread, on top of the main PCB, the switches for post 2622, -10, and J lpf, do not line up with the holes on the face plate. What it seems like is the sub DI PCB, looks like it should be on the bottom of the main PCB. Would this correct this issue? I have already soldered the 5 leads to hold the sub DI PCB in place on top of the main PCB. So that makes it very hard to remove. But wanted to check here to see if anyone has had this issue? Attached is a picture of what it looks like with the face plate. Thank you.
