TornadoTed
My components turned up today and I have stuffed the board, it looks fantastic and is so easy with the excellent instructions.
I have a few questions if you don't mind answering them. I apologise in advance as I am really new to electronics and some of these may be stupid questions!
I ordered exactly what was on the BOM. I have several parts left over.
1x .022uf Orange Drop, the BOM says 4 but I can only see 3 on the PCB
2x 3.9k Resistors, I used one at R24 above the Zero adjust trimmer.
1x 6.8k Resistor. I can't find this on the PCB anywhere.
1x 1k 1/2 Watt Resistor, I used 7 of them at R20, Grid/1k, R18, Grid 1k, R36, R31 and R32. The BOM says 8, where do I use the other one?
2x 1M Resistors. Where do I use these?
I currently don't have anything at,
NE-2 What do I need here?
R7/2k A bit confused as there is no 2k on the BOM.
J2 Do I jump or use a 1k?
J3 Do I jump or use a 1k?
R38/22k Do I jump or use a 22k?
.1 400v C-Cap Ceramic It says optional, should I use something here.
The diodes I have are these,
http://uk.rs-online.com/web/search/searchBrowseAction.html?method=getProduct&R=651-6135
Are they ok as I notice they are different to the ones in the instruction manual?
