Screening the face and or back is not a problem for me, I have a friend in the biz and I can get a screen for cost.
But I'm looking to do something a little different.
C11- Check the build sheet page 23 also note the comments on page 27. I used a .01pf 600v orange drop in C11, a Sozo cap would be nice here too (I may try one later). I did however use Sozo caps in in C2 and C3, very happy with this choice.
If you use Orange Drops, they will need to be 600v, as noted in the BOM. You will however run into a problem trying to fit the Orange Drops in the footprint areas of C8a and C8b, C6 and C12, and in the area of C9, it can get a little chummy. I would seek out ceramic caps for these --again as noted in the build sheet and BOM.
C14, I used 150pf, you can also order a 250pf and change out later if you like, or go with the ARCO 465 variable mica trimming capacitors and remove all doubt.
