Hi Gang,
Just got my 500 Revision F soldered and am waiting on a jig to arrive to do more tests. For the meantime, I have some very obvious faults that I thought perhaps one of you kind folks might be able to answer:
1. The unit passes signal but doesn't compress when powered on and it doesn't pass any signal at all when the bypass is activated! The input and output knobs do change the volume, though.
2. I did power the unit on with a whole bunch of cables, (in lieu of the jig coming in the mail) and was able to trace the audio signal using the Marc Burnley technique until I arrived at R6 at which point the signal died and I couldn't hear it anywhere else on the board.
3. Visually, it looks like I connected the VR1 and VR2 backward though they only fit in one direction into the pcb (they are currently not changing the meters).
Anyways, apologies for my DIY nubeness and if someone has a quick solution to the bypass situation I would be very grateful. I attached a pic.
