JoelCoteBergevin
Active member
It's the pad for the cathode. So just solder one end of a wire to the lead and the other end to the via under C21, that's it ?
Should work.JoelCoteBergevin said:It's the pad for the cathode. So just solder one end of a wire to the lead and the other end to the via under C21, that's it ?
Tiotever said:Hi, I'm just about to start my first FET/500 Rev A build. I can't seem to find components sorting sheets anywhere on line. Has anyone posted some already or do i need to make my own? Thanks!!
Tiotever said:I can't seem to find components sorting sheets anywhere on line.
Hairball Audio said:Sounds like you just need to flip the knob around.
The switch has 12 positions. 6 are used and the other 6 are just duplicated. You probably have your switch on the other side of the switch which is no issue except you need to flip the knob.
Not sure if that all makes sense.
t_carvalho said:Hairball Audio said:Sounds like you just need to flip the knob around.
If i flip the knob, the screw wont be secure on the flat side of the trim pot shaft. So i need to remove the pins, switch the flat side of the trim shaft to the other side and insert the pins again?
JoelCoteBergevin said:I have a Rev D pair and when assembling the faceplate of my second unit, the yellow GR led broke in half.. I want to buy a couple through mouser. I was wondering what is the part number for the LED ? I'd like to have the exact same thing. Thank you !
Tiotever said:A few probably stupid questions regarding a REV A build;
1) While populating the meter pcb i encountered some extra resistors and one missing resistor from the set. So I began triple checking values of resistors already soldered into the pcb. Several of them were reading 5-20k ohms less than their value prior to being stuffed. Is this normal or indication that I have stuffed an incorrect resistor along the way? In particular R206 reads 82k outside of the pcb and it reads 64k when its stuffed. Also note this is midway through populating the board. Many holes are still empty.
Tiotever said:2) R222 is 1.2k ohms resistor. My set came missing this value. Can I get a Mouser Parts number so I can order the exact intended resistor for R222?
Tiotever said:3) Where can I buy extra Grayhill Graphite Stops? I can't seem to find them sold separately on mouser. Perhaps you have a Mouser parts number for them or have any suggestions for where I might find them in Los Angeles. Thanks in advance for the help!
pearl said:I have a problem with Calibration step 3(Gain Reduction Tracking) on my rev a. The first 2 steps(Qbias Adjustment and VU Meter Calibration) works fine but when im trying to adjust the “Tracking Adj” to led -9 it doesnt work it, stops on led -5. I have built 2 units and its the same problem with both. any ideas?
I finally plugged in my two fet/500's rev D
One is working very well except for the metering. I can't seem to calibrate the VU or the peak.
The peak and vu are way to high when set to the output level specified.
The GR seems about right. It sounds great. Should the slam led turn on in slam mode? It doesn't at the moment
My other unit passes audio but doesn't compress at all, the is no difference with GR on or off even with the input cranked.
Hairball Audio said:Email Question:
Slam works like the original. The unit will peg hard right so the top red button will light and the meter will show GR erratically just like the original.
Often the trimmers can be set way off. Turn the 0 adjust and GR trimmer till you hear a slight "click" that is the end of the trimmer. They are 20 turn trimmers so rotate them each back the other way 10 turns and they will be centered. Now try to calibrate starting with zero adjust. As you make the adjustment go back and forth make small adjustments. If that doesn't work, you need to check the metering sections for errors.
For the non compressing one, did the qbias adjustment go well?
Mike
