I looked into that area on the board. I found nothing on closer examination I found that I had switched the .22 uF capacitors with the 220 pF capacitors. I made a careless mistake when moving decimals, I should have wrote it down. I believe this may be causing my issue. I broke one of the 220 pF ceramic capacitors when removing it, so I ordered some more. They should be in on Thursday or Friday. I have my fingers crossed that once I get the capacitors in the correct places that the calibration and LEDs will behave correctly. (Its weird that the voltage outputs are correct while the LEDs are not). Anyway I'll let you know how things go. I am using Rev A and D for my final directed project/dissertation for my masters.
-Thanks for all the help so far!
