mulletchuck said:Can you elaborate on how C11 was too big? pin spacing? too large a diameter? too tall?
Diameter. Just a little tight in that area of the pcb to fit that one in there. You're replacement should fit fine.
gemini86 said:It sound like the booster isn't operating. It runs off 24V so, it if there's a problem there, it will just be 24V. The two tube's heaters are in series and run off -24V. If everything in the tube circuit looks good, double check your boost converter. Likely failures are soldering of the surface mount components. Reflow them, make sure nothing is shorted or open. Make sure the controller IC is getting proper voltage from the regulator.
qmp audio said:I finally finished up the build! I have not powered up yet. Can anyone recommend a good testing procedure? Want to make sure things look good before i power on, and i want to make sure the voltages are right before inserting tubes. Thanks for any suggestions.
