Finter said:Hey all,
Just finished my Lola build, just plugged it in and went to run some tests.
Pushbuttons light up and relays click, and it passes a clean signal, but the meter doesn't show anything and the gain knob doesn't change the signal, but the output knob appears to function fine. I noticed someone earlier in this thread had a similar problem before they connected the meter board so I imagine my problem lies there. The meter does light up a bit when I flip the VU/ppm switch.
Any ideas of what I should check first?
Thanks in advance!
Sean
Hairball Audio said:I'd start by getting it working WITHOUT the meter PCB connected. Seems like you have two issues. A gain issue and a meter issue, get the gain/pre working right first.
Go through all of the Resistors in the vertical gain R's an mage sure they are in the right place/value. Is the gain loud or quiet?
Mike
samguaiana said:Hi there!
I grabbed two Lolas from a seasoned builder who was letting them go. I have a couple questions. First, do DOAs affect headroom? My signal will (pleasantly) distort almost anything after 35. I know there are CAPI 1731s in them. The output gain still has a ton of juice, but then I'm bringing the noise floor up, and its not as clean.
samguaiana said:Question two. One of them crackles pretty vigourously when the stepped input pot is switched. It will do nothing for a few clicks, then from 35 on it will start to pop. It will do this on the way down too. Then it will settle. It never does it unless the pot is moved.
samguaiana said:I know the builder soldered the top and bottom very cleanly to keep everything nice and in place. And they sound fantastic on overheads. But coming from something like my 512c's that were chalk full of too much headroom, I'm just caught off guard.
Thanks in advance!
Start with putting the gar doa's in. No changes needed. See if that gets it working.porkyman said:my lola isnt passing any audio. im not hearing any relays except on power up. im not a beginner. this is my 7th diy (actually thought it was the easiest) build but i still consider my self a noob because i dont really know what im doing. im just a direction follower. the only thing i can think of trying is replacing the doa's. i only have gar2520's and not sure if its ok to swap them. anyone have any ideas?
bulghur said:Hello Mike,
I bought two Lolas at different times and the meter lower white LEDs are different colours -- the older one is more yellow. What is the mfr part number of the new, cooler (as in colour temperature) white LEDs so that I an order them from Mouser/Digikey, etc.
Bulghur
Hi I have been building a lola mic pre amp and have gotten to the end of the main pcb installation. In the guide it says to test it out so that's exactly what I did. The led lights came on when I pushed the buttons but when I tried to connect a condensor, a 57 and a guitar, none of them worked or showed any signal. I went over all the steps and everything seems to be in place correctly but I did take note of a few things that I saw when I was putting the pcb together. One on the resistors brown and purple seem to be mixed up because when I use the website to calculate the colors purple can never be the last color but if I make it Brown then it adds up perfectly. That is a problem since it is clearly purple but after eliminating all the other resistors I must assume they either sent the wrong ones or used the wrong paint. Then I also noticed some of the colors that were suppose to have a .01 tolerance, have a 1 % tolerance according to the color code. Lastly I noticed they said to ignore the slots at the top of the board labeled opt c and opt r if you're using jh 990's but mine came with je 990s so I am unsure if that means anything. Any advice helps, appreciate it!
