>> What is the result if I change out the resistors to accomodate 24v but then use them in a 16V module?
> Really poor performance I would assume. Would be power starved.
Looks to me like very-little difference. The 33K or 68K set 0.9mA to 0.7mA in diodes. If this current were "'2X wrong", 0.35mA or 1.8mA, the voltage on one diode would change less than 50mV. There is roughly 600mV in the 150r and 88r7 resistors. 50mV change is less than 10% change in Q4 Q7 currents.
Q4 current, *also* Q1 Q2 parameters, sets input bias current and OSI. Input bias must tolerate much larger changes due to Q1 Q2 parameters. OSI has a very broad optimum, 10% change is hardly measurable.
Q7 current limits output current. The design value, 6.7mA, times Q9 beta, is the maximum output current. Rating is 260mA (13.8Vrms in 75r). If Q9 beta exceeds 260/6.7= 39, spec is met. This is right at MJE171's minimum. But a 10% change is not going to make-or-break performance.
I'd be inclined to use R10 R11 as 47K for all supplies +/-15V to +/-24V.
____
Manual Typos:
page 4
PCB Orverview s/b "overview"
These componets are mounted on the bottom s/b "components"
____
And.... nice project. Hope it does well for you.
____
Manual Typos:
page 4
____
