pvision
The switches are the same between 76 & 78 in the sense of what they do (with the caveat that the bottom right hand switch is a peak / average switch on the 78) and the fact that the buttons don't latch simultaneously - pressing one released any latched button. This is what I mean by non-latching
The 78 was built as a dual channel / stereo limiter rather than a dedicated stereo limiter. The distinction is a bit moot as the attack & release controls are common so I imagine the A/B / stereo switch only affects some parts of the sidechain linking
I assumed the 78 would have different switches as it has two channels. However, I had a quick a look at the differences between the sidechains of the 76 and 78. The 76 has two-pole switches for ratio, and switches signal & sidechain. The schematic suggests the 78 uses a different setup with the same switches as the 76 but switching L & R. The schematic I have doesn't show the RH channel so I can't be sure. A photo of the inside of a 78 should give the answer
Looks like UREI did some clever work adapting the 1176 into the 1178
Nick Froome
Nick Froome
