dale116dot7
If you don't have a variac, I would go through the circuit - each part at a time, and measure the base to emitter voltage of every transistor, measure the resistance of every resistor, and measure the forward and reverse voltage of every diode. You may have to desolder some connections to get good readings.
A classic three-stage amplifier (which this is one) needs to have its DC stuff all worked out first or it won't work right. Let's isolate stuff first.
Remove Q3, Q4, Q5, and Q6 from the circuit.
Solder a 220 ohm, 1 watt resistor across D2. Connect a 220 ohm, 1 watt resistor across D1. Remove all loads - the 8 ohm resistor, speaker, anything.
Connect a voltmeter to the output of the amplifier. Turn on the amplifier. Do you get 0 volts? Yes? then the input stage is either working or something isn't connected quite right. Measure the voltage on the collector of Q2. You should see a voltage between positive supply voltage and the output voltage (0). In addition, you should see:
0 volts at the base of Q1 (and Q1A)
0.7 volts below the positive supply voltage at the collector of Q1.
-0.7 volts at the emitter of Q1 (and Q2).
The output appeared to be at the right voltage, but it is possible for a subtle failure to cause a problem, so I've found it useful to make sure the input isn't causing a wierd problem that's being masked elsewhere.
Oh yea, there's always a possibility of oscillation. Do you have access to a 'scope?
