Hi All,
There are a lot of posts about the BV11 transformer, and a lot of confusion. Does the BV11 have a ratio of 7:1 or 10:1?
I mean: look at the different "clones" of the BV11 and there are some which use the 10:1, and some which use the 7:1? Are they both correct? Where there different versions?
Here is a list i compiled of the available options with their ratios:
AMI BV11a/r: 10:1
AMI T49: 10:1
Haufe T-8094: 7:1
Haufe T-8974: 10:1 (both haufe transformers are named as BV11 online? So that may be confirming the 2 versions?)
Cinemag CM-6511: 7:1
Beesneez B-BV11: 10:1
Fab V11: 10:1
Moby bv11 (groupdiy): ? Not sure. EDIT: confirmed to be 10:1
Advanced audio BV11: 5:1 (so probably got nothing to do with the real bv11)
Here is a discussion where Ericbazaar calculated that 7:1 would be the best choice: https://groupdiy.com/index.php?topic=66263.0, but why do most clones have a 10:1 ratio then?
Also in this thread there is mentioned that the BV11 is 7:1: https://groupdiy.com/index.php?topic=66243.80
And here is more mentioning of it being 10:1: https://groupdiy.com/index.php?topic=51862.360
What do you think? 7:1 or 10:1?
Thanks in advance!
AMI BV11a/r: 10:1
AMI T49: 10:1
Haufe T-8094: 7:1
Fab V11: 10:1
Thanks in advance!
