Had anyone had the chance to put values to the schematic?
http://www.omnipressor.com/MicSchLib/Bphantomc.GIF
I don't think it is a great design but I am curious about the use of a NS process 52 type fet at the front without a source resistor bypass cap(higher noise lower gain) and a process 50 as the SF.
The process 52 has a higher noise rating and input cap than a 50 reading the specs in my data book. That does not make sense
People seem to like this microphone. I have not heard one. Maybe it is because it has a very good MBHO capsule and OK body grill design people like it.
FWIW I have seen a picture of inside a horsh tube microphone from a site on the web. Again if you find it look close it looks like a MBHO capsule(very good) but the leads on the tube look to be short the heat of soldering and mechanical stress can hurt the vacuum seal I believe.
