radardoug said:Well, oscillation in this mode is probably because in a console, its fed by a beefier power supply with lots of cap in the filters. Try adding some large caps on the supplies. If the oscillation changes you are on the right track.
Also check your grounding is good and all necessary ground points are connected.
