Whoops said:With limited electronic knowledge you will not be able to do this.
Your questions are also so basic that you should be thinking in something else to do that would fit better your present knowledge.
There's a lot of EQ's already in 500 series format and normal rack format, you should try one of the projects that is already developed here in the forum and has an help thread already.
EQ's in 500 series format theres, helios 69, SSL 4k E, Neve 1084, API 550, Neumann W491, and much more...
fazer said:The dual stacked 11 pole switches will be a hard source but not impossible.
Have you played or Listened to this EQ? Just wondering what drew your attention to it.
Gold said:I like the discrete transistor 312 better than the 310 with the AM4 but they are fabulous sounding EQ’s. There aren’t too many active LCR EQ’s out there. I used an MM312S in my mastering rig for over 20 years.
PhilipMarlowe said:I can't find what the difference between the 310 and the 312 is. I thought one has a pre included and one doesn't. You say the 310 doesn't have a transistor? I only have a lo res schematic of the 312 unfortunately
the 312 has two discrete gain blocks. one for the eq, the other for optional line gain.PhilipMarlowe said:I can't find what the difference between the 310 and the 312 is. I thought one has a pre included and one doesn't.
