Che_Guitarra
I must have some kind of schematic dyslexia - it seems every project I build is guaranteed to need troubleshooting. The latest is a Vox wah project - modded off a Moutoulos PCB, true bypass, with variable R7 and C2 installed to nudge the wah's Q shape around.
Here's the board - i've superimposed back over the front to illustrate where the traces go:
And here's the circuit i'm going off - true to the Moutoulos PCB i'm using:
And here's the pedal in question:
The true bypass works, but when engaging the pedal i'm only getting a trickle of signal to pass. Flicking around the C2 rotary switch seems to do nothing, although toying with the pot-adjustable R7 does shape the note of oscillation. Transistors are Motorola 2N2222A's which were suggested by other pedal builders to be the best option for this gig - not MPSA18's as listed in the schematic.
If you can see any points of concern i'd be most appreciative if you can point them out. I just can't see where i've gone wrong.
![v847_zps7d8671ba.jpeg](https://proxy.imagearchive.com/47f/47f705974efd61a302b55fec7dd23de3.jpeg)
![ZXCxz_zps386b4290.jpg](https://proxy.imagearchive.com/c1e/c1e080394ef4f1d64560b51510d91736.jpg)
![IMG_0799_zpsf21b3115.jpg](https://proxy.imagearchive.com/875/8754c18545c88aaa2580d3e4d0e3710b.jpg)
![IMG_0791_zps1f15951f.jpg](https://proxy.imagearchive.com/2f9/2f97225c7a52360a340aba61190241eb.jpg)
