can someone recommend some free schematic/PCB software?
[quote author="NewYorkDave"]Yeah, that's the one--a nine-pin octal. (I know that sounds like an oxymoron, but that's the standard term for it).
Hey, is the pinout printed on the can? Could you post it? I have other nine-pin mic input transformers, but I'm not sure the pinout is the same as the Newcomb (and I haven't had a chance to trace out the Newcomb's sockets).
[/quote]
Yes it is on the can. Sure I will post it when I get home. If I forget just email me or sumpin.
[quote author="NewYorkDave"]Good tip! However, it appears that that feature is disabled in Orcad Lite :mad:[/quote]
Hmmm... I actually did it before I posted.
Capture CIS Lite Edition 10.0.0.s001
File->Export Design->DXF->OK
[quote author="kubi"][quote author="kiira"]Hey that worked beeyoooteefool! Check it out
http://www.2tough.com/~kiira/rec/micpre.jpg[/quote]
Kiira, that's a nice and simple design, I like it, but isn't a 5µF cap between the stages unnecessarily big, is it?
[/quote]
Hi Kubi,
Thanks! I wanted to make something VERY simple which would sound good and allow me to use pretty good quality parts.
I could replace it with a 2 microfarad or 2.2 sure. This was the first thing I designed and I wanted as little bass rolloff as possible for my voice which will sound kinda thin sometimes, so I made the output caps on the stages overly large. I may put in some switches when I rebuild it soon to switch in a .33 and a .68 ito give some flexibility on rolling off the bass, and also maybe some variation in the bias resisters to underbias some especially if I use 12ax7s instead of the 6072s... some distortion and lowered headroom would be what I was making. It is 5 years old now and I want to rearrange things.
