radardoug
I was sent a private message about the capacitors in this module so I went back and had another look at the circuit, and was shocked by the number of electro's in the signal path. So here is my answer to the private messgae.
There are 17 electrolytic capacitors in the signal path. A lot of these have been put in to make sure that offset cannot transfer from one stage to the next, but it is very conservative design. These caps will be affecting the low end.
For a start C1 and C2 can be removed and linked across. As long as the previous device has no offset, then they are un-necessary. Then you need to measure with a good voltmeter with high input impedance across the following caps. If there is no offset then you can remove them and link across.
C7,14,16,20,22,15,30,36,42,47,52,53,59,67,68.
Even if there is a little offset, say 10 mV, you can remove the caps. You can always take them out one at a time and check the circuit is still good.
