But wasn't it powered with Greek fire?Rumour goes The Oracle of Delphi used the same microphone as this one...
What transformer are you using?So.. there it is;
That's terrific! Well done!So.. there it is;
Seems to me it's an electromagnetic speaker, the listening device in many old style telephones. They work by superposing the AC field to a permanent magnet's field., which produces the variable force to a magnetic membrane.If the unit is thicker and heavyer.... it's not a carbon element;
It's two little coils with magnetic polepieces on a thin metal plate... so don't battery or phantom power these... it makes no sense.
They are not designed to be used as microphones, but still manage to produce some sound.They work for a super distorted crap sound only,
That would indicate a non-working carbon mic to me. All those I have used indicated something, quite variable, depending on position.carbon elements will give no reading at all.
Yup indeed, the membrane is magnetic, it seems to be a "rattling in a sort of controlled way" device.Seems to me it's an electromagnetic speaker, the listening device in many old style telephones. They work by superposing the AC field to a permanent magnet's field., which produces the variable force to a magnetic membrane.
Yup, I know, but people hook these up to phantom power, and that makes no sense...They are not designed to be used as microphones, but still manage to produce some sound.
Two working units gave me an OL readout on my Fluke when trying to measure resistance, could be that the corroded contacts are hard to probe and get a good reading of.That would indicate a non-working carbon mic to me. All those I have used indicated something, quite variable, depending on position.
Known as a 'receiver' in the US. This one looks like a 1950s-1960s era Ericsson maybe? The interesting thing is that diaphragm has to be spaced away from the magnet correctly or it will stick and won't vibrate. Very much like a LDC.Seems to me it's an electromagnetic speaker, the listening device in many old style telephones. They work by superposing the AC field to a permanent magnet's field., which produces the variable force to a magnetic membrane.
It's from an old "Dutch phone company " phone, late 50's could be right, bakelite horn, cottonwrapped wire.Known as a 'receiver' in the US. This one looks like a 1950s-1960s era Ericsson maybe? The interesting thing is that diaphragm has to be spaced away from the magnet correctly or it will stick and won't vibrate. Very much like a LDC.
@revmonkey ... that seems like a nice way to do it, I've seen some nice 600 Ohm telecom transformers on Farnell for less than 10 dollar.
