It has a LOT of power gain. That is the point.Overall the circuit does not make sense to me. What is the objective? A buffer, no gain or a buffer with some gain?
Not just a buffer but a buffer with a high drive capability balanced floating output. And a cost effective one. It does with one triode what most buffers with a similar power gain would take two triodes to achieve.Ok, just a buffer.
By replacing one of those triodes with a MOSFETIt does with one triode what most buffers with a similar power gain would take two triodes to achieve.
We could get really economical and just use a single power mosfet instead of the triode. Again requiring a well filtered supply. STF2N80K5 looks pretty good as a drop-in replacement, with fixed bias — 1/4 of B+ plus 4V. All diodes included, shrouded heatsink, low input capacitance (~100pF) right in the useful Vds range for us. Dunno how to extrapolate gain from the data sheet, but would be a pretty-frickin-low Zout regardless. 3 ohm Rds(on), suitably low, but might not matter here. Pretty much the same standards as choosing a source follower.By replacing one of those triodes with a MOSFET
I like how you’re thinking about this, but the idea behind the phase splitter and 2:1 trafo is that driving 2400 ohms requires way less current than driving 600. And it needs to work with voltages you’d normally find in a tube amp. In my post just prior to this one, I’m thinking B+ of 160V, because then the decoupling cap at the primary could be a 100V MKS-4, which is not unreasonably large. But other than that one part I’m with you on the postage stamp aspect for sure.Maybe like this...?
