Marc HENRY
Member
Hi all
i am very familiar making expensive point to point wired tube microphones![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
This time, i put a foot in reasonably priced transistor microphones![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
i have issues with two batches of pcb i ordered successively to cheap Chinese provider (jlcpcb)
Those circuits are supposed to be improved replacement circuit for Oktava MK012.
As i had crack and noise, i measured the pcb insulation (naked pcb, without any component)
i measured as low as 100Mohm, 40Mohm between tracks that are supposed to be perfectly insulated, at 2 or 3mm distance from one to another on the pcb !!
The worst one was made of...PTFE...!
the second one is very classical (green FR4)
Pcb's looks great, very clean...i try do dry them 12 hours at about 50°C (120-130°F), Z get higher, but one week later, with component in place, noise is back !!
i tried to air-wire HiZ (capsule bias and transistor gate) but there is still noise : little wind, and big wood cracking.
of course my components are those i use for usual microphone repair, i know them very well. to be sure i tested several FET and bipolar batches...
Sometimes (depends of the circuit and mod's i have tested) there is no noise. then I put the phantom power OFF for two minutes, and when i put it ON again noise is here again....!
Does anybody have experience like this ? with brand new pcb ? know what to do ?
Marc
Marc
