thor.zmt
Grid = -3,1V (and -520mV when I hold the mic)
I don't think you can directly measure the grid voltage.
Your meter is 1MOhm or 10MOhm, Even a rare and expensive 1GOhm precision DC Meter is a bit dodgy.
Thor
Of course ! I forgot that "détail"I don't think you can directly measure the grid voltage.
Thor
I will add a 12v z because things have to be done proprely... and so B+ can be raised to 95v or even 100vLast measurements :
cathode R = 112Ω
B+ = 93v
I lowered the load (from 33KΩ to 47KΩ) but because of the 96v zener minus 3v IRF +93v is the max. volatge I can get without having to add one more zener (6v ? 10v ?) > would be great if I can avoid to disassemble the circuit once again
(4*24v zeners already there) + 9,1v added today
B+ = 98v (can go now up to 100v > does change the plate voltage so...)
Plate = 73v
Polar. capsule = 63v
Cathode = 362mV (362mV/112Ω = 3,23mA)
R load = 47KΩ
Will now install the Tx out and soon do some audio tests...
Hum ? 100Hz ? because of the 29mV in the ground ?I suspect it will hum like.... something.
Thor
Just to avoid any misunderstandings. You always need a closed body (=Faradays cage) with good contact to ground or your mic will hum like hell.Yes I get a "nice" 50Hz hum but I tried without the mic body > will put it on and come back
That's just what the mic did : hum like hell, even if the headbasket was installed (I thought it would be sufficient)Just to avoid any misunderstandings. You always need a closed body (=Faradays cage) with good contact to ground or your mic will hum like hell.
No, that's not enough, the electronics must also be shielded, as you know now.That's just what the mic did : hum like hell, even if the headbasket was installed (I thought it would be sufficient)
This is not necessary, a clean signal routing and a good grounding scheme in a standard cable are sufficient.What about using 2 different cables (tied together) ? one shielded classic XLR and a 2 wires for HV & heater ? (but on the other hand, currents are so weak that I doubt it would change anything...)
I repost my (last) cable wiring...This is not necessary, a clean signal routing and a good grounding scheme in a standard cable are sufficient.
I do not use the 100R + 100nF and I connect the cable shield and the ground from the PSU output (B+ and filament together) at the post near to XLR input. The PE is connect to a separate M4 screw according to German safety standards.I repost my (last) cable wiring...
Yes the shield and the ground (wire to mic) are connected together to ground PSU (common for heater & HV)...and I connect the cable shield and the ground from the PSU output (B+ and filament together) at the post near to XLR input.
You mean to another "location" in the chassis ? why not group them at the same location ?The PE is connect to a separate M4 screw according to German safety standards.
Not allowed in Germany.You mean to another "location" in the chassis ? why not group them at the same location ?
Sure, the transformer is operated in reverse (10:1) here. Who says otherwise?Something I don't understand with NTE10/3...
It's supposed to be a 1:10 ratio 200Ω > 20KΩ (or 1:3 depends on secondary wiring), so shouldn't it be wired reversed ? primary at secondary and vice versa ? to lower tube output impedance by a 10 factor
CorrectLike so to get 10:1 :
Red output tube (thru 1uF MKP) / Blue (not connected) / Black ground
White XLR pin 2 / Yellow XLR pin 3
