I have designed a dual psu board based on lm317/337 and some lm78xx regulators. The transformer will be a 10va and current draw about 200ma, dispite it is depicted a 22va trafo.. sorry.. :
All the components, included the emi filter and transformer, are on the pcb.
1. There are some 230v traces under the transformer.
1b. Important question ¿ is it important trace separation, how much? some say about 8mm between 230v traces....
2. Both grounds 230v ac ground and psu ground (first rectifier capacitor) get together with independent wires to the CHASSIS gnd point. I know i could join both grounds together with an X2 cap.... it is another option....
attached are the pictures and schematics...
The values can't be read properly on the schematic... but after the rectifier i placed 2 x 2200uf 35v caps 2.2ohm resistor and 2200uf 35v cap. then 100nf --> lm317. 47uf/1k3. 1n4007/100R--> 100uf --> 100nf --> output idc connector.
The unregulated rail is 10ohms/1000uf35v.
The wire that gets back to the gnd pin at the IEC connector, is to join together the secondary ground to the primary ground at the gnd CHASSIS point.
The emi filter is a pcb type PREMO PE3V
Fuse 63maT
Transformer : 10va pcb type
Any opinion is wellcome!
JAY X
Fuse 63maT
JAY X
