Thanks for asking. There are numerous sound files embedded within the thread. The later sound files are the current version.How does it sound?
One way to get a little more loudness is to intentionally clip an A/D converter.
Some converters handle this much better than others. For the ones that excel at this, what is the internal electronics mechanism used?
Wrong.A diode "compressor / soft-clipper" could be build external (I feel KA's projects while very interesting is unnecessarily complex and still lacks the instant zero time constant reaction of tape or diodes).
Thor
Wrong.
I went with a VCA/Modulator approach to provide adjustability of Threshold, Ratio (hardness) and Make-Up gain using familiar controls and in a way that provides simple stereo control coupling.
That C doesn't exist once I used a cleaner rectifier. Otherwise there's no detector averaging anywhere in any of the versions so your statement about it not being 0 attack 0 release is completely inaccurate.
What I'm doing can be done in DSP for sure.
My only experience of diode clippers is in distortion stomp boxes and and guitar amps ,but to be honest its not something I like very much at all , imparting a kind of spitty sizzle to the notes edge .
I guess if threshold voltages/diode curves are adjusted correctly ,the effect can be made more subtle .
The effect of a movil coil meter on audio circuits is well established , old comps like the Federal drive a meter directly in the anode of the output , it adds distortion/compression in the audio path , its arranged as switchable in/out of circuit .
Funny, when I was designing dynamic processors I made a gadget that could increase the crest factor of dynamic music. Basically a variant tone burst modulator that could use music instead of a sine wave for the source. It sounded like crap but was very useful for stressing dynamic processors with extremely dynamic musical signals. I killed a lot of brain cells last century trying to make transparent NR compressor/expanders for tape recording.I agree.
I did some experiments where I reduced the crest factor of a song to various degrees with brick wall limiting, inverse-RIAA'd the results and then normalized the peak modulation of the I-RIAA'd files for them to be equal. In all cases the clipped samples, when RIAA de-emphasis was applied, returned progressively lower overall RMS levels.
Clipping/brick wall limiting worked against final RMS level. For vinyl it should be avoided and if you use it you sure are painting yourself in a corner.
I do however want to run an experiment where I first apply I-RIAA, mildly clip pre-emphasized transients and then apply RIAA to see if it can control sibilance.
Are you talking about low-level signals in the middle of the waveform, below threshold, which should be untouched?The issue with a soft clipper of any kind is that it introduces relatively distortion at levels that would normally be super clean.
I use clipper plugins these days, instead of clipping converters, especially since I very rarely run an analog mastering chain anymore. I find that a clipper before my final maximizer helps transparently shave peaks before the maximizer. Maximizers tend to have some tonal effect on the music, and that tonal effect changes with the amount of limiting it is doing. 1 or 2 dB of clipping can be completely (almost) invisible. In cases where I need a very high level master, I'll use two maximizers in series instead of a clipper followed by a maximizer. I find the Kazrog K-clip useful, as well as the Stealth Limiter before my Maximizer. Again, I'm using the maximizer for level and tiny bit of tone and the preceding clipper is for an extra (transparent) couple dB.Thanks for that input. I work a lot as an assistant to a mix and mastering engineer who is constantly insisting that they are behind us, and who generally masters to -14dB LUFS, but it doesn’t represent what either of us see when checking reference material.
I do think that some genres sound better pushed, but rarely do I think a track sounds best at -7dB LUFS. Obviously people having clipped has become part of a genre’s sound, as much as the hardware L2 was part of the sound of early 2000s masters.
The question for me is, what is it in terms of sound that you hear as beneficial about clipping as opposed to limiting? I’ve been mixing some pop/hip-hop of late, and I’m trying to understand why I should want to clip.
A decade ago, I knew why I did it on less transient sounds (to get a distorted bass sound, for example), but obviously clipping a whole mix or subgroup is a different thing.
Also, is anyone here then using clipping plugins (eg. SIR, Kazrog, that new acustica one), or is it “an analogue only trick”?
In my experience, when clipping slightly in the analog domain, the added distortion makes things sound a little brighter. I have done a/b tests not explaning what is going on to the listeners, and almost all people pick the clipped music as sounding better. Just my .02Thanks for that input. I work a lot as an assistant to a mix and mastering engineer who is constantly insisting that they are behind us, and who generally masters to -14dB LUFS, but it doesn’t represent what either of us see when checking reference material.
Agreed.No, below the actual threshold a "soft clipper" should be completely transparent.
I am talking about signals above the threshold but below the clipping level of the device behind the soft clipper.
For such levels distortion is increased.
Thor
The advantage of floating point is that it becomes virtually impossible to clip. I don't use a plug in for clipping ITB. I just raise the level of the 24 bit file until it clips to my satisfaction. Then I bounce the file and the clipping is baked in.I have experimented with 32 bit float files and clipping is fairly non-existent in the normalized files regardless of how clipped it was recorded...again a different beast.
I use a plugin for clipping ITB because I can then back off the amplitude a little afterwards and then bounce the file. I don't like having actual overs (samples at 0 dB) in digital files.I don't use a plug in for clipping ITB. I just raise the level of the 24 bit file until it clips to my satisfaction. Then I bounce the file and the clipping is baked in.
Despite that I decided to experiment back in 2013.I'm not a big fan of over-hyped saturated mixes. They're fatiguing to listen to. I call it "ear burn."
