john12ax7
One way to get a little more loudness is to intentionally clip an A/D converter. Some converters handle this much better than others. For the ones that excel at this, what is the internal electronics mechanism used?
[caveat] I am not a fan of clipping high quality audio paths.One way to get a little more loudness is to intentionally clip an A/D converter. Some converters handle this much better than others. For the ones that excel at this, what is the internal electronics mechanism used?
I'm putting the final touches prior to layout on a variable clipper now.
These are zener diode clippers.I have a pair of over kill clippers from prism sound. I’ve had since 1997. I need to pull them out and clip some track transfers. Are these still used?
I’m gonna guess the last two posters don’t master records for a living.
Please remember, the loudness wars are (hopefully) behind us. Primarily due to the preponderance of streaming services, pros have FINALLY banded together to try to arrive at realistic volume standards. Here's an excellent video that tells what the new level standards are, clarifies the volume vs. loudness concept, and mentions some of the software that's now available to achieve success on the various media.
"Why?", you might ask (we were having so much fun...). Well, because the various delivery services use varying amounts of compression (with varying thresholds), so if you mix "really loud", your work might hit the compression thresholds so early that your mix is played 6dB (or more!) below material that is only very slightly compressed. You might remember that in the old days, we put out disks marked "For Radio Play Only". That meant that those disks were not compressed to the degree that the records that were sold at the record store were. Again, that's because the radio stations often had 20dB of compression in order to fit their program material into the mere 40+ dB dynamic range that was available on American FM broadcast. When a highly compressed mix went to to the transmitter, it hit the compressors first, and the loud stuff shriveled.
Music sounds good when it’s pushed to a point, then your toast isn’t brown, it’s burned!
Thanks for that input. I work a lot as an assistant to a mix and mastering engineer who is constantly insisting that they are behind us, and who generally masters to -14dB LUFS, but it doesn’t represent what either of us see when checking reference material.Full time Mastering Engineer here working at a high level in L.A. - Lana Del Rey, Taylor Swift, Los Lobos (Grammy Winning), Rufus Wainwright etc etc.
The loudness wars are not behind us, in fact things are louder now than they ever have been in my 23 years of mastering.
Pros have definitely not banded to gather to agree anything, there are no standards and modern pop/hip hop/RnB and rock averages around -7 LUFS integrated but I have shipped records as loud as -3 LUF integrated (the mix was louder!).
People like Ian Shepherd have very little to do with the functioning industry making popular music, despite his good intentions.
