Toshiba still has a nice variety of very usable JFETs. Not only the well known 2SK209, but also the 2SK879 and 2SK880 (see my post #128), which Toshiba promotes for use in condenser mics and audio circuits. See attached datasheets. Active parts and available from Mouser and Digikey.I would be interested to know of any other manufacturers, it seems NEC (Renesas) and OnSemi are out of that business. I would not be surprised if all of the traditional Japanese, American, and European device vendors have completely ceded that market to Chinese vendors now.
Thanks. That's in the territory of stray capacitance. FWIW a femtofarad is abbreviated or written as fF when I looked it up.1f=1femtoFarad or 10E–15 Farad
SPICE schematics just use the metric prefix, the units are implicit to the device type.a femtofarad is abbreviated or written as fF
Why do you hold so much info hostage to people having to join MicBuilders?I go into some detail on 'electronic' noise of a LDC mike in Zephyr.doc You have to join.
You can clearly see the effect of EVIL resistors even in a Schoeps type circuit.
I need to pontificate at length on da various aspects of Condensor Microphone noise and especially the audible significance & annoyance of each noise type.
But don't hold your breathe for dis beach bum to tear himself away from da Great Barrier Reef![]()
In Spice simulation software, units are unnecessary. A resistor marked 100 is a 100 ohms resistor, a capacitor marked 1n is a 1nF capacitor, and so on, thus a capacitor marked 1f (note the lower-case f) is a 1 femtofarad capacitor.Thanks. That's in the territory of stray capacitance. FWIW a femtofarad is abbreviated or written as fF when I looked it up.
I find it rather surprizing that you're not already a member there.Why do you hold so much info hostage to people having to join MicBuilders?
Beside the point though - if he has something relevent to a thread, why not just post it, instead of "You have to join"?I find it rather surprizing that you're not already a member there.
Most members there are rather tinkerers than scientists, with some rather stellar exceptions.
I contribute there quite often when I can offer help in pure electronics.
Noise formulae are to be taken with a large spoon of salt, since the actual perceived noise is obtained by convoluting with the audition curve.Probably worth to mention the concept of "equivalent input noise". Whatever circuit you use, EIN is the one and only figure that counts for noise performance.
If we want to isolate the JFET as primary noise source we can use a model of a source follower (see pic sfollower).
Input referred noise density is
nd = (1 + Cin/Ccapsule) * SQRT (8kT/(3 gm)
and describes EIN perfectly. gm is the transconductance at operating conditions.
There is no way to reduce nd whatever circuit you design (at equal JFET operating conditions)...
That's what they are quite often.Just a remark, "Charge Amp with EXTREMELY LOW loop gain".
Each one his own lexicon.Try bootstrapping the load, a cascode on the FET.
THEN we will have something that deserves the moniker "Charge Amp".
I guess that's what my simulations showed. Seems we agree.And the conclusion that extra capacititance in the charge amp deteriorates gain and SNR similarly is correct, the degree of deterioration is directly inverse to loop gain.
A "charge amp" with minimal loop gain, will behave almost like the common source circuit, one with infinite loop gain will tolerate infinite parasitic capacitance and show no degradation in Gain or SNR.
When making his point involves several pages, I understand he's not willing to serve it on a plate, when it's just afew clicks away.Beside the point though - if he has something relevent to a thread, why not just post it, instead of "You have to join"?
Fair point; just seems like I see it often regarding rather short-explanation details that would take up little space in a post (not long tech dissertations) - just copy/paste the info from there to here.When making his point involves several pages, I understand he's not willing to serve it on a plate, when it's just afew clicks away.
Server space is at a premium, why encumber it with data that are already in the web?
What's more, it's like offering someone to open a dictionary rather than explaining, it offers infinite possibilities to learn new things.
I guess that's what my simulations showed..
Seems we agree.
"J-Fet as noise source in Mic's is tertiary or lower order"
"Putting a lower noise J-Fet into the circuit usually makes things worse"
Contradiction in one post![]()
There was an article in EE Times IIRC showing actual test results in microphone circuits.
cos as Abbey says, when I've written several pages of detailed info, just pasting it here would upset my careful formating & diagramsWhy do you hold so much info hostage to people having to join MicBuilders?
I was aware of this circuit when it was first published.
