Condenser Mic Test Jig?
pinebox
I dont go out of my way to work on many microphones, but they do come across my desk sometimes and I would like a more consistent way to test them. Years back I asked some people if I could remove the capsule and feed a very low oscillator signal into the circuit at that point to trace the signal flow quickly through the components. The consensus was yes, I could, but I have long forgotten the recommended capacitor value and expected signal level, does anyone use a method similar to this?
Ideally, the capacitor should have the same value as the capsule it replaces, so typically 50-70pF for LDC, 25-40pF for MDC and 10-20pF for SDC.
Signal level should be high enough for noise not polluting readings and not too high for avoiding clipping.
A value between 10-100mV should wotk usually.
