I am a little confused as to where the line is regarding what gets damaged regarding speakers and amps.
I have a Hafler P3000 which is 200w into 4ohms(per channel) which runs a 400watt each speaker bin (18inch driver and horn tweeter) at pretty loud levels. I run the Hafler at max and use my converter to control the volume. So far, no issues.
I bought a Samson Servo 170, which is 85watts into 4ohms per channel which I plan to use on the 400watt speaker bin so I can use the bins as a sub with my NS10's because the bins do not do mid to high frequencies very well, unless I eq the bins. I do not need to have it loud, as I am more of a listening level listener. I will then use the Hafler with my NS10s, that way I have a full range monitoring setup.
This is where it confuses me? I have read, if the amp is not powerful enough to move the driver, the amp will blow. If the amp does move the driver, it must move it continuously and not be stagnant or the speakers will blow? Is this correct?
Regarding my Samson and Speaker bins setup, if I leave the amp at max high volume and feed it signal that is low, what exactly gets damaged?
How should I be running speaker bin and Samson setup in order not to damage anything? What levels should I be considering and setting up on amp and converter volume? What should I be watching out for?
Thank you.
Thank you.
