Hello,
I have an old Soundcraft power supply that I would like to clean up for use with a 500 series rack. I've been able to lower the output voltage of the LM317 and LM337 from +-17v to +-16v by replacing one of the resistor with a variable trim. Phantom power is also marking 48v after cleaning and adjusting the trim pot.
The question I have is if there are other small capacitors I could add to the regulators to clean the dc signal up. Each regulator already has a .1 capacitor connected from the input to ground.
ROsa
ROsa
