globule_655
Member
- Joined
- Jan 22, 2012
- Messages
- 12
Hi folks
I just finished building my very first G7 in a T.Bone SCT800 body with Tim Campbell's capsule, EF86 NOS tube (tried Telefunken, Mullard and Tesla) and Cinemag 2480 output trafo
It really sounds amazing ! Thumbs up for Jakob's design !
Here's my question though : I was wondering if I could put a variable resistor in place of the 2x100k resistors in the PSU so that I could have a continuously variable polar pattern from omni to figure of eight..?
If I do that does this variable resistor have to be around 200k or the value only depends on how sensitive I want the change in polar pattern to be ?
Another question that's buggin' me : unloaded my psu delivers 150V DC on the B+ but this falls down to approx 125V when loaded. I read in many threads that it happens to many people who built the PSU according to Jakob's schematic. What I'm asking here is : is it really a problem as the sound of the mic is absolutely fine (it outperformed by far my TLM49) ! Should I try to rise the B+ a bit by changing the 15:220V transformer to a higher ratio ? Where does this problem come from ?
My last question is about internal wiring : I used the original PCB of the SCT800 and modified it for my build, cutting traces and used wires to make the connexions I couldnt do otherwise. I stripped an old AES-EBU cable that was laying around for this. I just wondered if my mic could sound better if I used another method for those connexions (I just dont know how this mic SHOULD sound...)
Thanks a lot for your help
Cheers !!
Cheers !!
