Couple of Green Pre parts questions
asm
The Woodlands, TX - US -
the 10K Log pot, i cant find it on mouser, also, whats this for?
the 1K and 20K multiturn, is this a trimpot or something?
the 100K one is labled "flat", but what are the others?
the ferrite's, are they the winded kind, doesnt matter, ect? theres no specs for them
thanks for any help.
t
Mouser Part #313-1220-10K
This works as a 6dB trim pot on the output.
The 1K multiturn is for setting CMRR
The 20K multiturn is for setting the peak detector DC offset
The 100K multiturn is for setting the LED meter levels
andrew
now i cant find a 22pF or 150pF cap in a polycarb or polyester. i can find something that small in ceramic, but the BOM is calling for a good quality, and they are all in large value radials
also, i cant seem to locate C21,C25,C26,C27, C20 on the schematic which these are for?
A 22pF ceramic will be fine here.
Try a 150pF in polystyrene.
The part numbers do not correspond between the schematic, BOM & PCB. They were done at different times in different circumstances & so have changed.
Peter
