I would like to know what is a proper way for RC coupling of EF86 based mic input stage to tubes like ECC82,83 etc.
I found several examples, one of them is "Four channel input mixing preamplifier" from Mullard's book "Tube circuits for audio amplifiers":
technicalscientific.com/data/Mullard_3_PA01.pdf
The other is 47 type coupled with R332k and C22n.
I would like to know if values of resistors from them, 332k and 470k, are typical for this kind of tubes? And does is matter if i put capacitor first and then resistors?
Mullard book says 470k is reducing crosstalk between channels and preventing grids of second stage to short when pot is at a minimum in mixer, while Winston o'Boogie says that this is load resisstor for EF86 stage in 47. I didn't find other examples with explanations, except for triode to triode coupling.
Miha
Miha
