Matt Syson
The current you should 'allow for' is 14 milliamps for each mic circuit (48 Volts through a pair of 6K8's in parallel) which would be the situation if the mic input were shorted to ground. OK there would be no signal either in this situation but it makes it robust against the damaged mic cable that happens to be plugged in for a day while you are doing something else.
25+25 ac is probably unnecessarily high as it will be lightly loaded so 22+22 is probably sufficient and less wasteful of heat.
Many BBC studios (TV) had phantom power applied at the wallboxes so appearing on the XLR but capacitors and resistors removed the phantom for the wiring run to the desk so that the desk /control room patchfield sees no DC. At least a couple of Calrecs had phantom power switches for each channel on the patch panel. Those mini EAO switches are very delicate and fiddly, necessary for a 40 channel patch strip.
While I didn't see the PUK UA8000 I was responsible for factory testing (and commissioning) 3 or 4 more. An upgrade to the Abbey Road desk (from 48 to 64 channels) and getting the heat out of the UA8000 in Stockholm (Abba's studio). Calrec Q series have phantom applied on the EDACs in the rear of the desk so on the mic circuit input.
Ramped phantom supply is a bit pointless as you never know if someone is about to plug or unplug a mic in the 'heat' of a session and all reputable manufacturers will 'design in' the ability to cope with a high voltage (possibly 48 Volt) spike. Interestingly only Studer (so far as I have seen) mention the necessity to demagnetise mic input transformers periodically to 'reset' the distortion that can occur by users 'spiking' the inputs with accidentally (presumably one leg of signal to ground short). Mr Lundahl has also commented that random spiking causes increased distortion even on line level transformers.
TL783 has the advantage of good ripple rejection and nearly bulletproof reliability which will also 'protect' the mains transformer and rectifier if you consider them part of the 'design'. They will also 'shut down' if you overload them or have insufficient heatsinking.
