Wordsushi said:FWIW, I asked Guosheng and he told me that Chris is using the Warbler 1 capsule, not the newer smooth top capsule, in the BA-67.
kingkorg said:Man, i have been using this smooth capsule lately, tested it against everything i have, true vintage u87, it is really something special. Amazing capsule, way above it's price range. I don't think there is any capsule widely available that hits this middle ground.
dmp said:I'm not sure what a flat U67 style capsule is. Isn't that just a U47 capsule?
Maybe you guys all know this, but there are flat capsules (47 & C12) and high freq boost capsules (u67).
Both the C12 and the U47 & M49 style circuits were flat freq response. The key capsule distinction was C12 style are edge terminated and U47/U67 are center terminated. In my opinion, cheap Chinese copies of edge terminated style do a better job than center terminated, in comparison to boutique capsules, like Theirsch (47) or Tim Campbell (12).
The U67 however had a filter rolling off the highs to restore a flat response after using the high boost capsule. They did this to reduce the white noise of the mic.
You can obviously mix and match flat capsules with flat circuits. I would not match a flat capsule with a U67 circuit without removing the high filter. And I would not put a 67 style capsule with +10db at 15kHz in a flat style circuit. Unless you want a really bright mic.
The other key feature of the different mics is in how they bias the tube. The C12/251 uses a cathode resistor with a bypass cap, the U47 uses the heater current to make a stiffer cathode resistor without a cap, and the U67 uses a negative heater voltage to set the bias and ground the cathode directly. The M49b used the U47 method, while the M49c used a cathode bypass cap (C12). The capsule bias in my opinion imparts a distinction to the mic sound that is hard to describe but easy to hear.
Building mics is a ton of fun and mixing and matching these characteristics is really cool. You'll be able to hear the difference.
