musika said:Anyway, I need to be able to disassemble those round grey parts to get to the circuit board on the other side. ...don't know what they are and I want to make sure I don't damage them, by unscrewing those. They have the reddish washers on the top.
Q113 is the driver for Q114, if Q114 is not working Q113 will try to do the work (and get hot)... I have seen power transistors fail open base, but it isn't as common as shorted collector-emitter, but in those cases the amp no longer passes audio, because the output is shorted to one rail or the other .scott2000 said:Here's a piece of the schematic with Q113 checked.......
JR mentioned a bias issue earlier......????
With power amp failures it is often good practice to replace all the devices connected to the one that released it's smoke... a subtle partial failure could lead to the new parts releasing their new smoke.musika said:Thanks JR for the explanation on this... it is great to have a suspect right from the start!
musika said:Does anyone know... are these power transistors readily available? Motorola (or others) 3295 and 3990.
I was reading somewhere that the print on the transistor is the actual Crown part number which doesn't make sense. So, the parts list should have the actual Motorola number.....
They tested bad??????
.musika said:I think you and JR are right - the Motorola part numbers are the correct replacement transistor parts -2N5631 and 2N3585. This really can be confusing.
Haven't tested yet...
Make sure to read section on troubleshooting.... It mentions some of the suspect areas to check as well when overheating is an issue. Oscillation can be caused by faulty resistors.
musika said:Is this what you are referring to ?
https://www.crownaudio.com/forums/index.php?/forum/22-amplifier-troubleshooting/
musika said:Thanks. This Service Manual is what I should have been looking at all along.
It does provide the transistor voltages along with a good description of the circuitry, the voltages of which I was planning on documenting when I tested them, but must admit I may be out of my league on this repair after a quick read.
Thanks again.
