D-87 Calibration [solved]
jBam
GDIY Supporter
Melbourne
EDIT: facepalm party... I had my scope on 10kHaz, not 1kHz!... been a long day haha....
Hi all - thought I'd ask via a new thread. Let me know if I should just tack this onto the build thread.
Just finished two d-87's... pretty chuffed to be honest :)...
One odd thing I couldn't quite clock in was even distortion in calibration. Just hoping someone can confirm this is either "not that odd" or "odd"!
Having just finished two other mics (Vamisound ldc84), I've seen nice clear calibration... not seeing it on my d-87, despite them sounding pretty nice.
So:
- D-87 m (blue pcb)
- Calibration is signal gen at 1k freq on the 1 gig R6 resistor, with scope direct to drain leg on FET.
- Everything wired up except capsule
*At low amp ~0.3v I get a nice clean sine.
*As I increase the upper half of the wave broadens, and the lower half thins.
* I can reduce this via trim to make it more sine like, but it then clips early on the lower half (I think... read below)
* when I increase amplitude in generator, it clips strangely... bottom hard clips, top soft clips...
Refer attached for my actual final product... looks wrong, BUT it is the point where it evenly clips, despite one half being hard and one half being soft... I.e. low amp is sine, increased amp starts to deform at the same time top and bottom, and pushed harder they deform the same amount, despite it being a different shape.
I can't actually get the top half top hard clip... it keeps that ramp shape.
Both builds are exactly the same... so not likely a dodgy part.
With capsule wired up, it actually sound pretty nice bit I'm thinking this doesn't seem right!
    2.6 MB
Oh lol... well, I thought that was the right place lol... I think I got that from a post chunger made in an earlier build thread... isn't that R6 the bias point where you attach a signal generator (if you're using a gen and scope... i.e. connect generator to that R6 leg, connect scope to fet drain)?
Edited for clarity*
Oh, sorry, i mis-read - could've sworn i saw something about "signal gen direct to JFET gate" 🙈 I shouldn't post here while sleep-deprived...
That should be about right - somewhere i recall recently reading the "max signal at cal input" for the U87 being 320mV or so (RMS, i'm assuming).
That being said, you'll be hard-pressed to see anything under 1-2% THD on an oscilloscope... Not that you couldn't use an audio interface for both providing the test signal AND monitoring the output (waveform AND spectrum / THD), while also providing phantom power to the mic, but what do i know? 😁 *cough* REW *cough*
Lol... all good buddy 👍
Massive facepalm from me though... same excuse as you after a **** nights sleep.
I must have knocked my signal generator or something... it was on 10kHz not 1kHz lol... I was just about to switch everything off when I noticed.
I was actually darn close with my 10kHz effort... slight tweak and now I have perfect symmetrical hard clipping I was expecting.
Sorry for wasting your time!
