k brown
Definitions are not semantics . . .
It's about mindset; particularly in management.
This was the difference between our Western factories and this Guangzhou site. It's why our Western factories couldn't produce the quality I wanted while the Chinese could.
And done all from Aliexpress parts costing peanuts and using a 16mm electret capsule?"Perfectly sounding U 87 build"
What else?
People are debating what one can do with two mics only.*WTF is going on here?
Obviously.And done all from Aliexpress parts costing peanuts and using a 16mm electret capsule?
Jumping in late here.Hi guys !
I have been seriously thinking for some time about lightening my equipment fleet. 90% of my activity is recording classical music ensembles, ranging from duos to sextets, in locations such as churches, chapels or small amphitheaters (maximum 100m2 / 300 square feet). I guess that multi-micking is ideal for recording modern bands (drums for example, even if the Glinn Jones method works fine to me) or for live music on stage where you must have each source independant for mixing. But I never record drums and stack to my classical ensembles.
I now own several pairs of SDC and LDC and I would like to learn to work with one and only one pair, as we listen with our pair of ears. I'm about to resell most of my mics also to get so money because times are hard. I have also eight mic pre channels (6 tubes + 2 OPA) and that's too mcuh for my regular activity which is episodic, like about 10 recordings a year...
So I would like to gather your opinions and your experience on these points:
- the relevance of working with only one pair of microphones
- the choice of this pair
I know that the ideal placement of a single pair is a tough challenge and that I will have to experiment much before obtaining good results.
I guess that a multi pattern pair of mics is unavoidable to set either ORTF and XY (cardio) or AB (omni).
My budget for this pair is a maximum 1000€ (for a used pair) and I thought about AKG C414 which is a great mic either in cardio than in omni mode... but the budget is more about 1500€ for a used but clean pair, so the last questions are :
- what do you think about the Lewitt 441 Flex (no OPT) and the Warm Audio WA14 (Cinemag OPT).
- If some of you have already tested these two mics, what are your feelings (and maybe some measurement ? would be great)
- is there another model inspired by the C414 in that price range ?
Best Regards
All i said was that XY and Blumlein are not the same thing, and everybody got their panties in a twist.WTF is going on here?
pedantic /pə-dăn′tĭk/
adjective
- Characterized by a narrow, often ostentatious concern for academic knowledge and formal rules.
"a pedantic attention to details."- Of or pertaining to a pedant; characteristic of, or resembling, a pedant; ostentatious of learning.
"a pedantic writer; a pedantic description; a pedantical affectation."- Like a pedant, overly concerned with formal rules and trivial points of learning.
If my response was specifically about any one post I would have quoted that one post.I feel attacked.
But at least I feel seen. I can live with that.
Posting a definition is kind of like a "if the shoe fits".
Blumlein could be faked with (2) pairs of X/Y at 180 degrees offset, I suppose.X/Y and Blumlein are not the same thing. I am in complete agreement with @k brown.
As I said earlier, I'm the last remaining High Priest of Tetrahedral Ambisonic mikes so I like coincident arrangements.@ricardo: What is your preferred method?
