Some basics:Tubetec said:Hi Trob
Hmmm ,maybe you could enlighten me then and explain how it works
The heads of a conventional hard disk actually "fly" just above the platter and are adjusted using a heating element. That is controlled by the circuitry on the drive and therefore you are committed to sending and receiving binary data as opposed to simply driving / receiving the head magnets directly.Tubetec said:Could a platter from an old hard disk be used to make a delay ? It certainly has magnetic properties ,obviously the motor would need to be changed as 7200 rpm would be way to fast. Anyway might be worth checking further into .
trobbins said:Post your 'restoration blog' on the telray forum for best visibility. What model did you pick up? The best restoration story I came across recently was due to a 'bullet wound'. Those oilcans are a nice blend of relatively simple mechanics and electronics.
