Search -> "this thread" -> arcoDoes anybody have any tips on how to mount the Arco-trimmers?
Haha, thanks Volker, the input ones are OEP, but I wound the power and the output ones. I must say that your PCB works perfectly and this has been such a great project to make! I will probably build another one and I'm planning on making a video where I show how I wound the OTs.Selfwound transformers? Cool
I would enjoy that, I'm a transfo winding nube. I want to learn the craft well!I'm planning on making a video where I show how I wound the OTs.
Beautiful work and congratulations for the self wounded trafos !So excited that I've finally finished my D-LA2A! I've wound the power and the two output transformers myself and you can check out how the unit turned out in the end:
View attachment 95023View attachment 95024View attachment 95025View attachment 95026View attachment 95027
Thank you! Yes, I used those meters. The meters work on both AC and DC, and I just wired the meters of the AC heater taps like the original did. The light is dimmer but I find it even better like that because I run the same meters on 12V in my 1176 and the light is to bright and they generate a looot of heat. So, check if that's enough light, if not, you can buy a 6.3V light bulb that you can install in the meter. I am not sure if don audio has it at the moment, but they are like small modules held by two screws on the back of the meter.Beautiful work and congratulations for the self wounded trafos !
Did you use the Don-Audio's WF1029X vu meters ? I've chosen them for my build and I'm actually finishing wiring it up but I wonder where to take power for the vu-meter leds... They require 12VDC. Can you tell me how you did it ?
R31 0.77/0.78might be the problem is in the sidechain amp. what voltages you have on the 12ax7 and 6aq5 ?
check the wiring to the peak reduction control is correct
My issues are that I can't see the meter needle moving up when applying gain on both channels
thanks for your help. Long time I think about buying an oscilloscope but don't have one yet.Voltages seem ok. Can you post a copy of the wiring diagrams ? That might help
Do you mean the meter is not working in output mode ? That should be fairly easy to troubleshoot, on the La-2a the meter just feeds directly off the output signal. Maybe there is an error on the wiring of the meter selector switch ?
Regarding no compression, if the stereo adj is set fully off the side chain signal is cut out. I know you are mentioning you set the trimpot as per the caibration instructions, I would try turning it the other way around just in case.
Best way to troubleshoot this would be with an oscilloscope and tracing the signal throughout the entire side chain amplifier to find where it gets lost.
