The black wire is the screen of the shielded cable. It is only connected to the PCB.So I just have a single wire going from bot side to the switch and the connector is jumpered.
Should the black wires be connected from side to side?
??? You can't use 5V DC instead of a Neon Lamp or 62V zener diode ...If I do not install the Zener and use the 5v rails instead is that ok? I actually blew one bulb trying to wire it.
Do I see a PSU mains switch in the middle of the front panel?Only the amp part works and the right channel has a 50hz humm and some hiss. If it touch the shield of gain or peak reduction pot it changes.
This is totally fine.They did not have molex connectors so everything is soldered.
As it warms up the operating point changes. First try swapping the tubes to see if the issue follows the tubes. If the issue does follow the tubes, narrow it down to a single tube, by continuing to make swaps. Most likely a tube in the sidechain, maybe the NE-2? (unless you used a zener diode)When powering up the unit, both vu meter needles are perfectly aligned on zero when vu meter switch on GR position, but little by little, the needle of channel A moves slowly to the left and after maybe one hour, it shows about minus 0,5 db. Don't have that on channel B.
What transformers did you use? What T4B?Considering how loud the signal i’m feeding the unit with, the compression is not what would be expected.
Any ideas what goes wrong?
Yes, shielded neat cabling is important in a LA2A. The shield of the cable should be connected at chassis ground on one end.The cable going to the gain knob seems to have the biggest impact. If i touch it on the rubber the hum goes
I'm not sure I understand - but with a 4:1 input transformer and peak reduction turned up you should be smashing the signal, more than -6 dB GR. Although with peak reduction turned down, you should not be seeing -3 dB on GR. So I'm not sure about your description. But it could be that the meter is not showing the GR correctly. You should look at calibrating the unit and checking the GR with the scope.Hi again.
Now i’m nearly set. Transformers work as they should, input ones take the input signal much higher, Output ones take it down. Slight moves of the gain pot make the signal way too loud above 9 o’clock. With a sine wave of 1k at 4 dbm in order to have unison level at the output (measured with my oscilloscope) the vu meter shows -3 db(gain mode). When i crank the peak reduction pot it goes down to around - 6 on the vu meter. Which means a gain reduction of 3 db max.
(tubes work well - i mean both sides show the same results, i use igs t4bx, and i haven’t made any calibration on trimpots yet but no trim pot is fully turned either side).
Look at who I am replying to in that post (not you)Thanks for the input Dmp, but i seriously doubt that my problem is cabling. Shielding is used to avoid hum and noise, twisting is a good practice to be done to every pair. I’m not talking about noise or quality of signal. I’m talking about db gain reduction quantity. Compression quantity (gain reduction) is my problem and not sound quality. Can noise influence that? I’m not sure.
Turn up the stereo adj all the way. If that is turned down you will have very little GRi haven’t made any calibration on trimpots yet but no trim pot is fully turned either side).
Sorry for assuming your post was for me. I’v already tried adjusting the trimpo. Not working. Of course i’ll try again.Turn up the stereo adj all the way. If that is turned down you will have very little GR
Register today and take advantage of membership benefits.
