Help with pedal switch please
sonolink
London-Madrid
A friend brought me a JHS Bonsai guitar pedal. The pedal works fine but the LED stopped working. It's a pedal emulating several versions of the Tubescreamer.
So I opened the pedal with the idea of replacing the LED. After desoldering it from the board I checked it and surprise! it works perfectly.
So I took a peak at the board and noticed that instead of the config:
9vdc -> current limiting resistor -> LED -> switch -> GND
There's a transistor. My guess is that the transistor is acting as a switch and for some reason is toasted, that's why the LED is not working. But I don't understand why there's a transistor there and if it has any function other than controllong the LED.
I've tried finding a schem, I emailed JHS technical support and even messaged Josh Scott (the CEO) through Facebook. I've had no answer whatsoever and couldn't find a schem.
Could someone help me out please? I've attached a pic of the part of the board where the LED circuit is.
Thanks in advance!!
    3.8 MB
Try shorting the negative lead of the LED directly to ground - which would bypass Q3. If it turns on, you'll know Q3 is dead
Q3 is dead....long live the LED!! :)
Can someone please explain the function of D21 and Q3? Is it only related to the LED?
If so, can I bypass this part of the circuit, feed 9v to the LED through a resistor and use one of the poles of the 3PDT swiswitch for the LED, somehow modding the board?
Yes, it seems to be an open-collector style connection acting as the switch for the LED.
The most likely reason to do that is you want a signal to switch multiple things in the circuit, and it doesn't work out to have the LED actually part of those other things, so you use a control signal to turn electronic switches on and off at the same time.
I read 1.76v across the LED terminals with the LED in place
That seems right-ish for the forward voltage drop of a green LED, but on the low side. I just spot checked a couple of datasheets and 2V seems like the expected forward voltage of most green LEDs.
How did you determine that the LED was working? Can you check the forward voltage when it is on?
No other components were previously changed? The main battery voltage stays around 9V when the pedal is switched on, it isn't dropping too low?
Check the voltage across the transistor collector to emitter (LED connection to gnd connection), it should be very low voltage when turned on.
Looks like you figured it out while I was typing.
It seems unlikely that JHS would choose a more expensive 3-pole switch if it was not needed. Are you sure you understand what all three poles of the switch are controlling? It's not that hard to change out a 3-pin transistor, why not just replace the failed component?
You're probably right but the problem is I don't know what transistor I need...
You can just remove that transistor and connect the LED directly to ground. The footswitch should still turn it on/off judging from your drawing of how its wired. The transistor is likely behaving as sort of "soft start" so the LED doesn't cause a popping sound when turning on. I would try it without the transistor just to see how it behaves. And if the LED seems too bright (because of not having the transistor's resistance in series with it anymore) you can increase the size of R62 to compensate. But it appears to be 3K3, which should be enough to keep most LEDs from being too bright.
MMBT3904 or equivalent would be the usual device for that kind of use, been around for decades, 10 cents in single quantities. The problem is if you don't have one or find someone to give you one, you pay $0.10 for the part and $4.95 in shipping and handling if you have to order one.
There is also a chance it is a 2N7002 MOSFET.
Now that you know specifically what the problem is, try asking JHS what they recommend to replace a damaged Q3. That is a lot more specific question than "pedal broke, what could go wrong?" so maybe more likely to get a response.
Connecting the LED directly to GND doesn't seem to work. The LED stays ON all the time.
I've got a few 2N3904 around so I strapped on one to check:
The LED goes on but fades out after a second...
Q3 does appear to have a marking, though it can't be made out from the photos.
I tried my best :)
I'll try them again :)
Thanks a lot everyone for all your ideas and suggestions!
Sono
With the device out you should be able to tell by using a diode tester to see if it is an NPN device or a MOS device. A transistor should show about 0.6V threshold for base to emitter or base to collector, a MOSFET will not show a voltage where any current flows (or at least shouldn't, unless the gate insulation is damaged).
A positive ID on the transistor markings is really required here if possible.
Manufacturers often use the same parts in various different parts of the circuit rather than having a huge inventory of parts, so if this individual marking is unclear, it may be possible to find a different one which may have clearer markings, and obviously be the same part.
