[silent:arts]
a four layer PCB for a small tube project 8)thestudio said:How about using different layers within the pcb? ????
but you can't twist PCB layers either
yes, it is not on the PCB and needs to be added at the VU meterelectrisizer said:do i still need the 3k9 resistor for the VU? (like it wa said at nrgrecording)
Randyman... said:My Chassis should be here any day now, and the PCB's are stuffed with the exception of the Trimmer Caps. Since they obviously had a reason for calibrating the original units, I can't help but assume these Arco Trimmer Caps and trimmer resistors for the T4B's should be installed and calibrated to have an "in spec" unit? I have 4 of the Arco's staring me in the face (seem to be hard to find abroad) - so I'd like to use them.
Thanks for any further info. I'm hoping to get this done very soon (once the chassis arrives), and I have a project that would benefit immensely with this compressor squashing away "in spec" !
Thanks! 8)
horvitz said:I just placed an order for this one:
http://www.antekinc.com/details.php?p=671
What are you looking at for $66? As far as I can tell, there are only two choices for 250V. The one with the single secondaries is $29 (and out of stock), the one with the doubles which I bought is $34.50. Haven't actually received mine yet though so I can't comment on it.
Randyman... said:Also - How did you mount the Arco Trimmer Caps?
